the end-result RGB always ends up higher than the original texture RGB (and the RGB values become nonequal from each other, ie, it's not a true gray anymore).
The same thing happened to me when I was in 16-bit mode, when you zoom in on the ball the pixels are dithered. But when I changed to 32-bit mode it was a solid gray color. If this isn't working for you then I'm not sure what is going on. You may have to reset your computer after changing the color depth. Also, after you hit the print screen button, which program are you pasting the screenshot into?
