Old 11-21-2013, 10:04 AM
Zhi Zhi is offline
Thank you Jeff. It works if the ground is an imported 3D model (i.e. a .osgb file). But if I create an object on the fly (for example, using the viz.addTexQuad() method), it seems your way does not work. Is it possible to let the avatar to follow the surface of an on-the-fly object?
