Old 11-18-2013, 02:56 PM
Hi Maya,
Sounds like you can use a proximity sensor. If you set your sphere as the source of the sensor in the example below, you can do something when someone enters the area (or leaves the area). See http://docs.worldviz.com/vizard/vizproximity.htm for more info.
import vizproximity
male = viz.addAvatar('vcc_male2.cfg', pos = [0,.15,.5], euler = [180,0,0])
#Create proximity manager
#Create target and add to manager
target = vizproximity.Target(viz.MainView)
manager.addTarget(target)
#Create sensor and add to manager
sensor = vizproximity.Sensor( vizproximity.CircleArea(1),source=male)
manager.addSensor(sensor)
def EnterProximity(e):
    """@args vizproximity.ProximityEvent()"""
    print 'entered',e.sensor
def ExitProximity(e):
    print 'exited',e.sensor
manager.onEnter(None,EnterProximity)
manager.onExit(None,ExitProximity)
