If I understand correctly, you want your code to handle different screen sizes, so that you can test your code on with a Lite license and a full license. Furthermore, you only seem to have a problem when the window size changes. So would your problem be solved when the window does not change size (as in a fixed size window, or fullscreen). If so, this code should help you out:
import viztask
viz.go(viz.FULLSCREEN)
def getSceenSize():
	yield viztask.waitDraw()
	[WindowWidth, WindowHeight] = viz.window.getSize()
	print WindowWidth
	print WindowHeight
viztask.schedule(getSceenSize)
 The code first tries to go fullscreen. With a full license, WindowWidth & WindowHeight should be your screen resolution. With a Lite license, WindowWidth and WindowHeight should be the windowed resolution (standard 800 x 600). Furthermore, this screen does not change in size afterwards. Then, you could create SignSize, SignCentre, and SignRadius based on these values.
