Old 10-31-2013, 08:22 AM
sleiN13 sleiN13 is offline
I'm already preloading the avatars, but I still need to initialize the code around the avatar, this involves creating some additional helper object on the avatar together with some other time consuming code. In all it takes between 5 to 7 ms to construct an avatar making loading even 1 avatar per frame noticeable. Using the director method it take 70 ms but the framerate is influenced a lot less. I assumed the async methods of Vizard would work well with Vizard?
