Also, another question that came up was, Im trying to track and LED inside a Lab, do I have .dae loaded and when I rotate the map 90 degrees in Yaw of the map, it appears to be 90 degrees pitch of the helmet that Im using... how can I make the Yaw of the map be the same as the helmet?
