Dear Jeff,
Thank you so much for your response. We have tested the provided code for the Oculus HMD. Thank you so much for your help, the html problem is solved; however, we still see two 'crosshair' images when We tested your provided code (adding the code below):
import oculus
hmd = oculus.Rift()
viz.link(hmd.getSensor(), viz.MainView)
The same issue was also displayed when we tested vizinfo. We did not have this issue with zSight. We are guessing that the problem may be because the images for left eye and right eye are mirrored positions and consequently the left and right images are required to be slightly different (for a stereoscopic view), but we are not sure. We appreciate your assistance again in this regard.
Thank you in advance.
