Old 10-17-2013, 09:00 AM
i would also like a solution, for similar reasons. It would be disastrous if the rate of data-polling was capped at the vertical sync rate of 60 hz. Eye-tracking, motion capture, and many other systems must run at rates >60 hz to be effective. I would be grateful if you could post your findings!
