Old 07-08-2003, 03:14 PM
FlyingWren FlyingWren is offline
...if it helps you debug:
the end-result RGB always ends up higher than the original texture RGB (and the RGB values become nonequal from each other, ie, it's not a true gray anymore).
The actual RGB value can differ depending on where I take the screenshot (ie slight differences when I move the viewport)
