Old 09-19-2013, 09:51 AM
The viz.POST_SWAP_EVENT is probably the closest you will get to a vertical sync event, without diving into low-level code. The event is triggered after the frame buffer swap, so it should be essentially right after the monitor vertical sync trigger.
