Old 09-19-2013, 08:18 AM
ChrisMa ChrisMa is offline
Importing Vicon Tracker Data
I found the same issue for Version 3.0. I'm using Vizard 4.0 in the 90days Trial Version.
I want to get the data of segments and markers tracked with Vicon Tracker 2.0 (32Bit). I had some warnings and errors. They were solved by opening the port 800 in the Windows Firewall at the Vizard PC.
If I run the following code, a new window opens, and Shows the World Viz logo on a black Background. The Interactive window stops at loading the Basketball.osgb.
# Add a world
scene = viz.addChild('dojo.osgb')
ball = viz.addChild('basketball.osgb')
ball.setPosition([1,1,1])
vicon = viz.add('vicon.dle',0,'192.168.10.1')
body = vicon.getBody(0)
marker = vicon.getMarker(0)
print body.getName()
print marker.getName()
** Loading Übung_Vizard_1.py
Loading File: dojo.osgb
Loading File: basketball.osgb
On the Nexus PC I allowed Tracker to send and recieve data through the Firewall. In an other post somebody said to allow "kinematic data" as an Output. I don't know where to find that.
Thank you for your help!
ChriMa
