Old 09-18-2013, 03:45 PM
The command viz.collision(viz.ON) is used to prevent the movement of the viewpoint through objects.
Is the cylinder part of the haptic simulation? If not, the car will follow after the haptic device through the cylinder because they are linked. If you want the car to move in a different way you can disable the link once the car reaches the cylinder and animate it going over.
