There is no command to remove textures. Also, when you load models, Vizard caches the textures so that other models can share the same textures. So even when you delete a model the texture is still in memory. The best solution would be to allow the user to clear the cache and free up the memory. This feature doesn't currently exist, but I will look into adding it to the next release.
