Old 08-28-2013, 10:25 PM
Kevin Chiu Kevin Chiu is offline
The code should works, you feel it didn't work because you didn't give any amount of degrees in Euler to the viz.MainView.setEuler() function.
So it remains looking forward, try to put some number in it and it should change your main view orientation.
Here is also some information for your reference.
http://docs.worldviz.com/vizard/Movi..._viewpoint.htm
