Old 08-23-2013, 05:57 AM
madeinjava madeinjava is offline
Question Window always on top
Hi all,
Is there any way to get my vizard window always on top?
I have an application that will run parallel with vizard's window together in the same screen. but when I click on my app button the vizard window is covered again with my main app.
This is my vizard window setup:
viz.window.setPosition(500,500)
viz.window.setSize(700,300)
viz.window.setBorder(viz.BORDER_NONE)
viz.window.setFloat()
even though in the vizard help the setFloat() function will set the window to stay on top but here in my case it does not.
Its work only when during the compiling I press the vizard logo. then I get my vizard window always on top. but I can not make it when publishing to exe since you can not press the vizard logo when you publish to EXE file.
Is there any way to get my vizard window always stay on top?
Thanks!
