Old 06-03-2005, 02:49 PM
Vizard is written entirely in C/C++. So it would not be compatible with Jython or Java. The best thing you can do is have your Java application manually start up Vizard and communicate with it through some form of IPC (Interprocess Communication). Why do you need to use Java? Are you using it for a GUI or calculations?
