Old 06-02-2005, 05:38 PM
The cfg file contains a variable path. When animations are loaded the path variable will be prepended to the animation filename. If that path exists in the local directory then it should load fine.
The animation state is determined by the order in which it appears in the cfg file. The first animation file is state 1 and so on.
Currently there is no functionality to get an animation state by name. I can add this to the next release.
