Old 06-02-2005, 05:33 PM
Have you tried out Vizard 2.51? This might fix these problems you are experiencing.
When you parent an object to another it will inherit the transformation of the parent. The same thing is done when loading files.
When your world is running click on the "Display Stats" button in the toolbar. It should print out some statistics of your simulation, including how much texture memory you are using. If this value is near the amount of memory on your graphics card then this is most likely your problem. How many textures do you have and how big are they? If you wish I could create a plugin to compress the textures of an object. This might help a little bit.
