Old 07-08-2013, 11:04 AM
mape2k mape2k is offline
Inconsisten movement speed of the viewport
Hello all,
we are designing experiments in Vizard that include both automated movement as well as manual movement (joystick, keyboard) of the viewport through an environment.
Here, we have come across an interesting problem: Whenever we have manual movement, the movement speed is inconsistent. This means it is a) dependent on the loaded environment and b) dependent on the desired speed that is set.
a) More complex scenarios produce higher deviations in movement speed (but only for manual movement! The automated movement works flawlessly)
b) Higher speeds produce higher deviations (at 10m/s it is about 0.5m/s slower, at 30m/s about 1.5m/s slower)
We are realising the joystick and/or keyboard movement with the following code:
if math.fabs(jy) > joyDeadzone and -zoneX < jx < zoneX: 	# translation
	if jy > 0:	# backward
		view.move(0,0,viz.elapsed()*-joyMovSpeed)
	if jy < 0:	# forward
		view.move(0,0,viz.elapsed()*joyMovSpeed)
elif math.fabs(jx) > joyDeadzone and -zoneY < jy < zoneY:	# rotation
	if  jx < 0: 	# left
		view.setEuler([joyRotSpeed*jx*viz.elapsed(),0,0],viz.HEAD_ORI,viz.REL_PARENT)
		if  jx > 0: 	# right
	pass
Could it be that the function viz.elapsed() is causing the deviation in movement speed?
All the best and thank you!
