Old 06-24-2013, 11:37 AM
Thanks. I think the problem is with your normal map lookup code. The texture color values range from 0 to 1. However, the normals need to range from -1 to 1. Also, it appears the green channel in your normal map is flipped. Try modifying your normal map lookup to the following:
vec3 texNormal = normalize(texture2D(NormalMap, gl_TexCoord[0].xy).rgb * 2.0 - 1.0) * vec3(1.0,-1.0,1.0);
I tried running your shader with this modification and it appeared to render the normals correctly.
