Old 06-13-2013, 11:33 AM
Perhaps you can add a cube that is sized to match where the marks are placed. Then you can get which face of the cube and position of the cube using viz.pick. You could then perform some calculations to normalize the pick location to match texture coordinates. In the following example the cube is not visible because the viewpoint is inside it and back faces are not rendered by default:
import vizshape
env = viz.addEnvironmentMap('sky.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
vizshape.addGrid()
cube = vizshape.addCube(size=80,splitFaces=True)
def getPickInfo():
	info = viz.pick(info=True)
	print 'name',info.name
	print 'point',info.point
vizact.onmousedown(viz.MOUSEBUTTON_LEFT,getPickInfo)
