Old 05-24-2013, 11:26 AM
There are several things that could be causing this, but it is most likely either something going on with your materials or smoothing groups. I'd also turn off the "use indicies" settign in the OSG exporter if you're using it, since this can sometimes cause unexpected behavior as well.
