Old 05-09-2013, 10:10 AM
You will need to create your own model with the proper UV coordinates.
The sample image you provided looks like it can be applied to a standard cylinder. Try the following code:
import vizshape
viz.fov(60)
panorama = viz.add('panorama.jpg')
cyl = vizshape.addCylinder(radius=100,height=200,slices=100,flipFaces=True,top=False,bottom=False)
cyl.texture(panorama)
viz.link(viz.MainView,cyl,mask=viz.LINK_POS)
