Old 05-24-2005, 11:59 AM
When you want the ball to appear behind the net you would do the following:
#Ball behind net
net.disable(viz.DEPTH_TEST)
net.draworder(16)
ball.draworder(15)
Note: the net object must be separate from the ground object. When you want the ball to appear in front of the net do the following:
#Ball front net
net.enable(viz.DEPTH_TEST)
net.draworder(16)
ball.draworder(17)
Like I said earlier, this method breaks down if you have other objects in the scene that need to be in front of the net.
Out of curiosity, why do you want the ball to be attached to the screen?
