Old 04-19-2013, 10:34 AM
Instead of using timer functions you could insert vizact.waittime actions into the avatar's action sequence. The gallery.py world demo (Help -> World Demos) shows an example of that. Also, take a look at task functions, which are useful for controlling program flow.
I'm not sure if one of the vizact.ontimer commands is within a function. Please use the code tags to preserve indentation. If you only want a timer function to be called once, register the function with the ontimer2 command and set the repeats parameter to 0.
