I've tried to get the Z800 working on a 64 bit OS but never succeeded. Emagin support is minimal to none existing. Only solution I found was switching back to a 32 bit version of windows 7. You also need to run Vizard with administration rights to let the plugin function correctly. I've also have a custom build z800 vizard plugin but I'm not sure anymore if this was because I needed some extra functionality or the vizard plugin didn't work correctly. The emagin SDK pdf should provide enough information if you need to write your own plugin.
