					Originally Posted by  farshizzo
				I would recommend adding the arrow to the viz.ORTHO layer, instead of viz.SCREEN. The SCREEN layer works in normalized (0-1) units, which is what causes the aspect ratio distortions. The ORTHO layer works in pixel units, which preserves the objects aspect ratio.
 Thanks for your prompt reply. It works. I only need to resize everything proportional to the size of the window, which should be fine.
Cheers
