Old 04-02-2013, 07:04 AM
Sven Sven is offline
unfortunately, I can't use the Quadro card with the Sony, as it only has DVI-Outputs and no HDMI. I tried several DVI2HDMI Adapters, but none of them worked properly.
By now, I'm fairly sure that the problem is with the Sony HMD - if I combine the tracker with a small portable monitor instead of the HMD, the lagging vanishes. Googling about the HMZ-T2 and lagging also brings up several hits - apparently, this problem did improve a lot since the T1, but it is still there. Maybe we should wait for the T3, or at least tell our test subjects to avoid fast head movements...
