Old 04-02-2013, 05:45 AM
kartoffelsalat kartoffelsalat is offline
eMagin Z800 Windows 7 64 bit problem
I want to use my eMagin Z800 3DVisor Tracker Device with Vizard under Windows 7 64-bit.
But I can not install the USB-drivers.
When I install and run the Z800 3DVisor Software Utility it shows a message "Sensor Init Error".
When I install and run the Setup Wizard, it crashes with this error message (it is longer, don't know if you need it): "An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)".
So i am not able to install the USB-driver for my Windows 7 64-bit system and because of this I am not able to use the tracker with Vizard, which fails to connect to the tracker with this error message: "ERROR: Could not connect to eMagin device. Error: 80000016", using this line:
hmd = viz.add('emagin.dls')
I also tried the installation tricks for Windows Vista (Device Manager, update driver), but this also does not work.
Can anyone help me with this issue?
kartoffelsalat
