Old 03-29-2013, 08:02 PM
There is currently no built-in way to access the vertices, but you can save the model to the STL format, which is a simple text format that contains all the vertices. Here is some sample code allows you to iterate over the vertices:
model = viz.add('logo.ive')
def getVertices(node):
	"""Iterate over vertices"""
	node.save('temp.stl')
	vertices = []
	with open('temp.stl','r') as f:
		for line in f:
			s = line.split()
			if s and s[0] == 'vertex':
				yield float(s[1]), float(s[2]), -float(s[3])
verts = list(getVertices(model))
