Old 03-20-2013, 10:32 AM
It sounds like it could be a limitation of the graphics card. Did you run the same script on the system with the quadro card? What is the framerate when Vizard is running (Press F4)? Have you tested with a simple script? Just load a simple model like gallery.ive with your tracker and display settings and see if the lag is there.
