Old 02-15-2013, 10:51 AM
You should avoid using the node.bumpmap command. It is not documented and only exists for backwards compatibility. You will need to use GLSL shaders to make use of normal maps in Vizard.
The following thread contains a Vizard script for performing a parallax/bump effect:
http://forum.worldviz.com/showthread.php?t=1145
