02-12-2013, 02:33 PM
Originally Posted by farshizzo
Clustering can also be enabled through a config file. Is there a "vizcore.cfg" file in the same directory as your script? If so, try opening it and commenting out the line that specifies the cluster clients, "viz.cluster.master.clients".
Indeed! Farshizzo +1
