Old 05-16-2005, 11:46 AM
mspusch mspusch is offline
Hi Johannes, I have to appologize for not being up-to-date with the two features we talked about -
1) it turns out that the old MS-speech recognition plugin which used to be supported in VRUT is not supported any more. So, if you want speech recognition, you will need to add it as a plugin.
2) the feature for adjusting colors for red-blue glasses has not been implemented, so the only anaglyphic mode Vizard supports is the red-blue. What are the artifacts you see when using red-blue glasses? Maybe higher density color filters in the glasses would improve performance?
m.
