I am using this method to apply textures & shader
tex0 = viz.addTexture('image0.jpg')
tex1 = viz.addTexture('image1.jpg')
tex2 = viz.addTexture('image2.jpg')
tex3 = viz.addTexture('image3.jpg')
node3d.texture(tex0,node = 'node_name', unit = 0)
node3d.texture(tex1,node = 'node_name', unit = 1)
node3d.texture(tex2,node = 'node_name', unit = 2)
node3d.texture(tex3,node = 'node_name', unit = 3)
vertCode = """
fragCode = """
uniform sampler2D texture0;
uniform sampler2D texture1;
uniform sampler2D texture2;
uniform sampler2D texture3;
varying .......
void main()
tex0 = texture2D(texture0, texcoord);
tex1 = texture2D(texture1, texcoord);
tex2 = texture2D(texture2, texcoord);
tex3 = texture2D(texture3, texcoord);
gl_FragColor = function(tex0,tex1,tex2,tex3);
shader = viz.addShader(vert = vertCode, frag = fragCode)
uf_texture0 = viz.addUniformInt('texture0',0)
uf_texture1 = viz.addUniformInt('texture1',1)
uf_texture2 = viz.addUniformInt('texture2',2)
uf_texture3 = viz.addUniformInt('texture3',3)
node3d.apply(shader)
node3d.apply(uf_texture0)
node3d.apply(uf_texture1)
node3d.apply(uf_texture2)
node3d.apply(uf_texture3)
 Using this method I can not apply more than 4 textures. If there any alternate method so that I can take full advantage of fragment shader then please let me know.
Thanks !!
