Old 12-07-2012, 11:59 AM
It sounds like you need a card that support quad buffered stereo, like a nVidia Quadro card. Then after enabling stereo in the nVidia control panel run the following code in Vizard:
viz.go(viz.QUAD_BUFFER | viz.HMD)
This won't effect turning on stereo but you'll also want to set the field of view in Vizard to match the glasstron. For that use the viz.fov command.
