			I tried to create an easier example but I was unsuccessful. I am not sure how to replace the DAQ for instance with a keyboard. Can you tell if my syntax where I assign values to the transformations is correct? The only difference between transformations is the theta value. Therefore all transformations should work, or none should work.
