Old 11-10-2012, 06:15 PM
tokola tokola is offline
Thanks for replying. I have tested the DualShock with that code before and it didn't work. I haven't probably checked the Rumblepad which eventually reads the right analog as twist (y axis) and slider (x axis) data.
Is there any way to read the Sony DS3 as well, or it's dependent on the driver? It basically runs using a virtual controller called MotioninJoy, since the device is originally for the Play Station. Is there a list of recommended joysticks for use with Vizard or any other plugins designed for specific joypad devices (similar to the wii.dle)?
