Old 11-01-2012, 04:12 PM
I would recommend posting the most concise example code possible that shows your problem. By creating a simplified example you maybe able to figure out what's going on. If not, then at least it will be easier for others to help troubleshoot. Also please make sure the example can be run directly by others, which means you may need to swap resources with those included in Vizard.
