Old 09-27-2012, 04:22 AM
mhead10 mhead10 is offline
Sometimes my .obj and .wrl files would load, and sometimes they would not. Therefore, to always get my 3d files to load (with their respective texture), I did the following to yield successful results:
http://www.javelin-tech.com/blog/201...w-to-sketchup/
.obj load correctly if they come from Google Sketchup (and not Solidworks directly)
1. Thus, save ACIS (.sat) in Solidworks
2. Next, download draftsight
3. In DraftSight’s command line type: “IMPORTSAT” and press <ENTER>. Locate the ACIS file you saved at step #1 and import it in DraftSight.
4. Save this file again in DWG format.
5. Open SketchUp
6. Import the DWG file you saved at STEP #4.
7. Save sketchup model as .dae
8. import into vizard using:
viz.add('name.dae',pos=[x,y,z],euler=[0,0,0],scale=[1,1,1])
Hopefully this will be helpful to others who do not have Blender.
