Old 09-21-2012, 11:32 AM
mhead10 mhead10 is offline
import ctypes
import numpy
import viztask
import time
import threading
nidaq = ctypes.windll.nicaiu # load the DLL
int32 = ctypes.c_long
uInt32 = ctypes.c_ulong
uInt64 = ctypes.c_ulonglong
float64 = ctypes.c_double
TaskHandle = uInt32
read = int32()
# the constants
DAQmx_Val_Cfg_Default = int32(-1)
DAQmx_Val_Volts = 10348
DAQmx_Val_Rising = 10280
DAQmx_Val_FiniteSamps = 10178
DAQmx_Val_ContSamps = 10123
DAQmx_Val_GroupByChannel = 0
DAQmx_Val_GroupByScanNumber= 1 #interleaved
# initialize variables
taskHandle = TaskHandle(0)
max_num_samples = 2
data = numpy.zeros((max_num_samples,),dtype=numpy.float64 )
print
def CHK(err):
if err < 0:
buf_size = 100
buf = ctypes.create_string_buffer('\000' * buf_size)
nidaq.DAQmxGetErrorString(err,ctypes.byref(buf),bu f_size)
raise RuntimeError('nidaq call failed with error %d: %s'%(err,repr(buf.value)))
#Main Program
CHK(nidaq.DAQmxCreateTask("",ctypes.byref(taskHand le)))
CHK(nidaq.DAQmxCreateAIVoltageChan(taskHandle,"Dev 2/ai0:1","",DAQmx_Val_Cfg_Default,float64(-13.0),float64(13.0),DAQmx_Val_Volts,None))
CHK(nidaq.DAQmxCfgSampClkTiming(taskHandle,"",floa t64(1),DAQmx_Val_Rising,DAQmx_Val_ContSamps,uInt64 (max_num_samples))); #(samples/sec/channel) #ContSamps
CHK(nidaq.DAQmxStartTask(taskHandle))
# stop/clear when I want to end program by mouseclick
def onMouseDown(button):
CHK(nidaq.DAQmxStopTask(taskHandle))
CHK(nidaq.DAQmxClearTask(taskHandle))
viz.callback(viz.MOUSEDOWN_EVENT,onMouseDown)
def obtain_value():# continuosly read the DAQ values
CHK(nidaq.DAQmxReadAnalogF64(taskHandle,1,float64(-1),DAQmx_Val_GroupByChannel,data.ctypes.data,max_n um_samples,ctypes.byref(read),None))
print data
x=0
def loop(): # loop which call for DAQ values to continuosly be read
while x < 10:
obtain_value()
viz.director(loop)
viz.clearcolor(1,0,0) #proves I can use vizard interface with continuous data aquisition
# add haptics
sensable=viz.add('sensable3.dle')
device = sensable.addHapticDevice(name = 'Left')
device.workspace.setScale([100,100,100])
device.workspace.setPosition([0,0,0])
[/CODE]
