Old 09-04-2012, 01:46 PM
mhead10 mhead10 is offline
Sensable Open Haptics-"Failed to load plug-in: 'sensable3.dle'"
I am trying to use Sensable's Open Haptics (version 3.1) with Vizard 3.0. Therefore, I am using
sensable=viz.add('sensable3.dle') in Vizard like docs.worldviz suggests. However, I still get the following error:
Failed to load plug-in: 'sensable.dle'
Therefore, I am wondering if my problem is that Open Haptics Academic Edition does not come with a license (since I know O.H.'s is installed). I called Sensable and they said a license is not required to run, and therefore it was Vizard's fault.
I installed all 3 different versions of Open Haptics with the same result.
Any help will be appreciated.
Thanks!
