Old 09-03-2012, 12:48 AM
sleiN13 sleiN13 is offline
What is the correct way of returning values in de command function, Vizard 4 had a nice .set() method. I can't seem to find something similar in the vizard 3 example codes.
I did see you could extend the float data array but I would also like to be able to return some strings with certain tracker error messages.
