Old 08-30-2012, 10:43 AM
nabrahamson nabrahamson is offline
Originally Posted by farshizzo View Post
Quad buffering is usually enabled through the Manage 3D settings page of the nVidia control panel. There should be an option labeled Stereo - Enable, which you will need to enable. However, I don't believe quad buffering is supported on the nVidia NVS series drivers. It's usually only supported on the Quadro series.
However, most 3D capable TVs support side-by-side and top-bottom stereo modes, which Vizard can output on all graphics cards. Just use the viz.STEREO_3DTV_SIDE_BY_SIDE or viz.STEREO_3DTV_TOP_AND_BOTTOM stereo modes. Be aware that these modes will cause you to lose half the available resolution since each half is stretched to fit the entire screen.
I'll give that a shot. Thanks.
