Thread: Video function
Old 08-23-2012, 11:58 AM
Are you running on Windows Vista/7? The recording feature does not work properly on those versions of Windows. This has been fixed in Vizard 4.0 though.
Try the following as a workaround.
  1. Browse to the Vizard bin folder (e.g. C:\Program Files\WorldViz\Vizard30\bin)
  2. Right-click on winviz.exe and select Properties
  3. Select the Compatibility tab
  4. Check the Disable desktop composition option and click OK
Depending on your graphics driver, this should fix the issue. It should also improve the overall rendering performance of Vizard.
