Old 05-03-2005, 01:53 PM
vmerget vmerget is offline
Checking the settings of the graphics card was the first thing
I checked. Unless I missed something, it's 32 bits. I also tried
a JPEG that I created in Photoshop -- an RGB image that
"just happened" to have R == G == B for all pixels --- and it
displayed a full range of greys. I looked very closely at the
screen, just to see if it were dithering 16 grays to create the
illusion of ~256 grays, and I don't believe it was.
I'll probably try creating the image as a true grayscale as an
experiment later, just to see if the result changes. I didn't
do so originally because I wanted the flexibility of being able
to write a colored image, even if the image was currently
greyscale. In particular, I might want to have a key that
adds some colored dots or squares at key points on the
mage. (Basically, the plugin enables you to dynamically
update the texture from a Python string containing a grayscale
or RGBA image in SGI format.
Here's the code that creates the image:
void InitImageGen(void *imagegen)
VizImageGenObj *self =
reinterpret_cast<VizImageGenObj*>(imagegen);
strcpy(self->version, "strtexture v1.0");
self->user[0] = 0;
self->dataSize = 0;
int imageWidth = nearbyPowerOf2(self->x);
int imageHeight = nearbyPowerOf2(self->y);
if (imageWidth <= 0 || imageHeight <= 0) {
imageWidth = 256;
imageHeight = 256;
osg::Image *image = new osg::Image;
image->setImage(imageWidth, imageHeight, 1, 4,
GL_RGBA, GL_UNSIGNED_BYTE,
new uchar[imageWidth * imageHeight * 4],
osg::Image::USE_NEW_DELETE);
clearImage(image);
self->image = image;
self->texture = new osg::Texture2D(image);
CommandImageGen(self);
self->status = 1;
And here's the shortest routine I use to write fill the image:
void clearImage(osg::Image *image, uchar red = 0,
uchar green = 0, uchar blue = 0,
uchar alpha = 255)
for (int ii = 0; ii < image->s(); ii++) {
for(int jj = 0; jj < image->t(); jj++) {
uchar *pixel = image->data(ii, jj);
pixel[0] = red;
pixel[1] = green;
pixel[2] = blue;
pixel[3] = alpha;
image->dirty();
-- Dan Merget
