Old 08-06-2012, 01:27 AM
victorqx victorqx is offline
Hello farshizzo,
I did consider using the vizhtml module, but at the moment I'm using a top projection on the tablet to show a floor plan of the current scene. I like this floor plan quite a bit and assume that it would be quite a lot of work to supply this in the vizhtml module. Therefore I would like to stick with running the Vizard cluster client.
I assume that mouse events are not supported in this manner (otherwise you would have lead me towards a solution :-)), so I'm first going to try to overlay a transparent application for the mouse events and use socket communication to send them to the cluster master. Last resort would be to run the tablet stand-alone from the cluster and synch the viewpoints and scenes myself via sockets (although using the vizcave module makes this so much simpler!)
Regards,
Victor
