Are you using a glove from Immersion or CyberGlove Systems?
If you are using a CyberGlove Systems glove, then you need to use the cyberglove.dle extension, instead of immersion.dle. Also, if you are running on a 64-bit machine, things get a little more complicated. You need to install the 64-bit drivers for the glove. However, Vizard is a 32-bit program, so you also need to manually place the 32-bit CyberGlove SDK DLLs (CGS_VirtualHandDevice.dll, CGS_VirtualHandCore.dll, etc...) in your Vizard script directory.
