Old 07-31-2012, 07:33 AM
NI_LAB NI_LAB is offline
Hi again,
ok so after a while we tried this glove again.
We are making progress, but it still does not work.
What is working now:
- the DCU shows the cybertouch glove and its movements correctly
- in the DCU we can do the test stuff and the vibrators all work fine
- we can load the immersion.dle now (I installed the latest update VirtualHandSDKSetupV2_10.exe of the SDK from this site
The problem:
- When adding this line
glove = immersion.addCyberTouch()
we get this error:
** Loading Vizard2.py
immersion.dle Immersion Extension
** ERROR: Failed to connect to CyberTouch. Make sure Device Manager is running.
Initialization Failure NETWORK: APPEARS TO BE DISCONNECTED(-101) for C:\Program Files (x86)\Immersion Corporation\VirtualHand\
** ERROR: Failed to create extension sensor with immersion.dle
** Load Time: 0.23 seconds
The DCU is running, it shows a glove.
Could it lie in the fact that we use 32bit-Vizard, but only have 64bit-Virtual Hand SDK? If so, how can we solve it?
We have installed the VirtualHand SDK from the CD in this folder:
C:\Program Files\CyberGlove Systems\VirtualHand SDK
but the update installed itself into this folder:
C:\Program Files (x86)\Immersion Corporation\VirtualHand.
