Old 07-24-2012, 10:45 AM
Do both monitors have the same resolution (1280×720)? Also, I'm not sure if this is true for all cases, but duplicating displays might only be available for monitors that are attached to the same GPU.
If extending across both displays works, then you can have Vizard go fullscreen across both monitors and render a stereo signal to the HMD and a mono signal to the laptop monitor. This might actually be better than duplicating the display, since you will get a full resolution image rendered to the laptop monitor. The downside is that this can hurt the rendering performance, depending on the complexity of your scene.
